- Feb 28, 2006
You could well be applying too much pressure. Perhaps counter intuitively I think it is easier to dull the edge as you seem to have on the fine grades. Aside from any tendency to want to press harder to make the abrasive work better papers like 2000 are themselves much more compliant than the rougher stuff. I sharpen big blades on whole sheets of wet and dry on big bits of foam that are a little softer than a mouse pad. It's even easier to see the effect on that. Fine stuff up the 2000 end wants to wrap the edge readily whereas 120 doesn't. Either ease off on the pressure when using the fine stuff or make your backing stiffer. It's probably worth you going to 400, and when you're happy you've got it all dandy there carefully working back to 2000 again and strop.
