- Apr 3, 2011
Hey guys. Looking at making some scissor blades for a glue factory. The blades themselves are about 6" long w/ an OAL of about 8". Obviously they have a chisel ground primary and secondary. They will be cutting about 3" diameter rolls of wet glue as it extrudes from the machine. They fail eventually, through wear - not fracture or deformation. What I am looking for is a stainless, probably high-ish carbide (for the wear resistance), but I need it to be magnetic as I will probably have to surface grind after heat treat to make sure the inside area is truly flat and not warped.
I will have to introduce a bow to each blade, after HT (just like scissors have).
Any recommendations would be appreciated.
