i know usually in threads like these (folder-abuse), knives such as Striders, TOPS, Greco's, Sebenza's etc. are most often advised, or "get a prybar/prybaby/fixed blade........"
however, my situation is different, i'm looking for something CHEAP that will take some abuse like prying open a door/crate and needs a sturdy tanto-tip for the occasional "hard-object-stab".
i've already decided that i need a tanto point, it's just the best for tip-abuse.
i also know that i can't and won't afford a Strider, TOPS or any other overbuilt, high-priced folder. i need an affordable tactical folder with a tanto-point and sufficient grunt to withstand, or at least survive, hard prying.
i'm currently checking out CRKT's M16. i've read lots and lots about it, including a multi-review in a knife-magazine where the M16 actually won and took 1st place because of its capabilities and reasonable price. the buck-strider tanto and spyderco atr came in second.
what do you think of CRKT's M16? is it a good choice? i know aus-8 steel isn't that great, but i don't mind edge-holding much. i like to sharpen.
another thing i always wondered was this: for prying, would you be better off with soft flexible steel like aus8, or a really tough and hard steel, like bg42? let's assume in this comparison a blade-thickness of 3.5mm's.....
i also wonder if it matters in what position/direction you pry with a folder that has a liner-lock? is it better to hold the knife edge-up and twist to the left?
any other suggestions are welcome too. criteria: cheapo folder suited for tip- and pry-abuse.
tia for any help,
dennis
PS. i have experienced 3 buck-striders (2 tanto, 1 spear) and what i liked was the blade's point and strength, but i managed to get bladeplay on all 3 of them......
buck-striders are also quite expensive in europe. thus my interest in CRKT's M16 line
tia for any help,
dennis
