Neem Handled Giant Seax
Well folks, I finally finished finishing my Neem Handled Giant Seax. Purchased on this DOTD, you can get all the specs there if you want them. When this one came in I was pretty stoked because the piece of wood on it was really nice. So I went right to work on it. Sorry I didn't take any WIP pix, I tend to sleep erratically due to my health issues (try looking at all the different times I post sometime) so 99A% of the time I am either wishing I could sleep while I am working or it is too dark for the pix to come out well or both. So I will just tell you the "How To" in words and hope it helps.
First, I carefully taped off all of the metal parts, both to protect the from the sanding and finishing materials and to protect me from cutting myself. I always use the blue masking tape because it comes off easily and leaves no residue behind that I then need to work at removing. This handle came finished and smooth but Santosh had also polished all of the wood pores shut on the felt wheel. So in order for any of what I wanted to work, I had to do a but of sanding to open them back up. Otherwise the Boiled Linseed and Tung Oils would not penetrate and I might as well save my time and leave it alone. So I first used a bit of 600 grit sandpaper and carefully took off the hard polished shell from the handle. Once this was done I put five coats of BLO (DILUTED 2:1 BLO:Mineral Spirits) onto the handles, using all the handle would take per coat, then leaving is wet for an hour before sanding it with more 600 grit to remove the hardened BLO between coats. After I did this five times, I then switched to pure, straight Tung Oil and using the same method, put on three more coats. On the last coat, instead of 600 grit sand paper, I used 1000 grit paper to give it a bit of a luster, then I buffed it lightly on a dry, loose leaf, buffing wheel on a power drill.
Next I peeled off all of the blue tape. One the metal was exposed I took more 600 grit sandpaper and sanding in one direction, along the length of the blade, I knocked the shine off of it and gave if a bit of a Villager look. This part isn't completely done, when it is I will have a uniform, satin finish on the blade rather than the high polish it came with because I intend to use this blade. I prefer the satin look because it hides finger prints and scratches a lot better than the high gloss finish plus it is easier to clean off juices and gunk (though this seems counter-intuitive, it is true but I can't explain it). Finally, I never tried putting Renaissance Wax on wood as a finish before but I read that it is supposed to, as the layers build up, impart that rich luster that gives wood depth. Plus, I do know it is great as a protector against stuff soaking into the wood and staining it. So this plus the oils should really keep the handle looking good for years to come. I put a very light coat onto it, then lightly buffed it off with a cloth.
Enough warty! Let's see it already!
main.php
main.php
main.php
The handle is sound even though it appears cracked. I wish there was a good way to photograph it but I hope this give you an idea of what I am seeing. It looks like a chunk of buttery ice with grain and a rich shine in the sun light in person. Some folks don't care much for light woods but I like all woods, light or dark and for the light ones, Teak, Curly Maple and Neem really seem to be my favorites. I also like the way Neem has a spicy smell to it when you sand it...
So here are some more pix of the Giant Seax, this time verses my "normal sized" one with a Satisal Handle from Dil Kami that I have had now for close to a year but seem not to have gotten around yet to fixing up, much to my shame.
main.php
main.php
and finally just the Big One in hand...
main.php
I hope you all enjoyed this presentation and another addition of show and tell with warty. :D
I likey very much, great job on the handle, Going to have to add that to my list of things get. Thanks a lot Warty:D:D. Great write up as usual.
Nice finish. On a sort of almost related note, how does the size of the handle feel to you? Mine feels really huge, and I have fairly largeish hands (9 inch spread). It's like Santosh just scaled the whole thing up, blade, grip and all. I was pondering grinding it down a bit but hadn't gotten around to it yet. It may turn out like my Glock 21, feels huge on fondling, but I don't notice the size in action. :) How's it feel to you?
...On a sort of almost related note, how does the size of the handle feel to you? Mine feels really huge... How's it feel to you?
It never dawned on me to make it smaller around, I like it like this and it is big feeling, no doubt.
I have big hands as well, and I guess for me this Giant Seax is just right for them.
I haven't used it much yet but I think it is just right for me at least. :thumbup:
Hi Warty,
this is just a suggestion and you may have already done this, but sanding the problem area and applying super glue to cracks helps to prevent future problems.
And, that is a nice knife!
Dave
Very nice, Wary. The only seax I have any experience with was one that Andy C. made and sent out for a pass around on another forum.
It took me a little while to get used to the difference in feel and action from the khuks I normally use for bush work. But after that, I found it to be quite capable.
This type of blade, in various sizes, did serve some of my ancestors very well.
It's nice job you've done, Warty!
To avoid future crack, you can use super glue to fill in the gaps or cracks.
In full tang handle, the force is mainly endured by the metal tang, then the light woods are nice here as well. It gives more weight to the blade and helps reduce overall weight some how.
In here, we often use Guava wood for handle as they are both light and not brittle.
OK, thanks folks first for all of the compliments, if you could see the wood first hand you would be even more impressed. It really came out nicely and the wood has that inner glow and rich luster that I was hoping it would develop. I attribute this mostly to using multiple coats of the oils plus the buffing and also the wax which really did make a difference without making it slick. What looks like a crack there is actually more like what I would call "spalting" since there is no gap in there at all. I did try to put some of my super thin-super glue into it and it just sat there without entering the "crack". So I broke out a magnifying glass to take a look at the handle and all I see there is a dark line with some kind of gunk in it. So I sanded off the glue and went on to oil and wax the handle.
The only part I was disappointed with how it came out was at the base of the side of the scale in the top picture. If you look at the "before" picture from the DOTD posting that DanSmithy added, you can see there are some grain rings there that did not really pop out when oiled. In fact, that side of the handle really seemed to have a very dense chunk of Neem on it that simply would not drink in the oils as deeply. It did develop the glow and luster but the grain sort of disappeared. I am hoping that it will come out in time like the handle on my Tamang has done. If the weather permits, and if I feel like it after I deal with the tooth ache and the dentist tomorrow (:(), I'll post pix of the Tamang handle as it looks now plus the way the YCS Karda I got when I received this Giant Seax turned out. The Karda I did a bit differently in that I just tossed it into a jar of diluted BLO for a good soak for a few days, then did a one day/24 hour soak in Tung Oil after sanding it in between. I wanted to do an experiment with soaking the wood and it turned out nicely as well. :)
Here are some blades I can get into. Nice and straight, too bad there is no finger guard. Glad that your handle polish came out nice Warty.
Nice pix, thank you for sharing
The cracked handle actually suits the Dark Ages look of the piece; it adds a lot of character!
Good finishing job, too.
