- Jul 30, 2006
As Mike said in his thread, these edges are extremely fragile. I liken it to being related to a master craftsperson with a volatile temper: tread on eggshells and your efforts will be rewarded beyond your expectations; get even a little careless and expect a devestating blowout. I don't go 4 per side or up to 400,000 mesh (14,000 to 90,000 is fine enough for me) and do add a microbevel.
Now if you look at angles (and we all do), you'll see the grooves scored into your knife with a given grit are deeper at the edge when the angle is smaller. The grooves add friction and if the edge isn't perfectly aligned (as in any edge after the first several uses), that friction aids in starting the cut. I don't have the ratios all worked out, but a 600 grit edge at 40 included degrees and an 8,000 grit edge at 8 included degrees both feel equally 'toothy.' On the flip side, I've thinned out edges at low angles with coarse benchstones and coarser sanding belts and the blade felt like steel wool. So you might well be experiencing a relative identical level of polish in your work knife as a sharpening geek has in a kitchen knife.
YES SIR. I agree there is a difference between angle and smoothness of the blade surface.
I find myself cutting heavy plastic a lot (homeowner fixit projects). For that I like a somewhat more oblique edge angle, but a very smooth surface finish on the cutting edge.
I do edge comparison testing at 15° per side. My EDC edges are sometimes 15° and sometimes 20° per side. (I'm still not sure what angle I really like best for everyday chores.) If I'm sharpening with the Sharpmaker, I'll stop at the fine rods. If I am using DMT stones, I stop at the extra fine.
