- Aug 15, 2005
Here is an update on my Nelsonite vacuum chamber problem;
Jim was kind enough to send me several gaskets made of Durabla, a rubber gasket, and some grapfoil tape. Durabla appears to be fibrous material, somewhat similar to some automotive gaskets. I was unable to compress any of the durabla gaskets enough to get a seal around the rim of my vacuum chamber (actually a HarborFreight 2.5 gal paint pot).
I then tried the heavy duty rubber gasket Jim sent. The rubber gasket did seal the chamber. My vacuum container has never held a perfect seal, so every few days I have to suck the air out of the chamber again. I've never established whether the leak is through one of the teflon taped threaded ports or through the rim of the lid. In any event, the rubber gasket held up for about a week, then I began to lose the vacuum more rapidly. When I removed the lid today, I found that the rubber gasket had gotten quite limp, and it's inner edges were beginning to deteriorate.
I have not yet tried the grapfoil tape, but at this point most of my open Nelsonite is used up. Rather than opening another gallon of Nelsonite, I think I will order some of Cue Components Resolute and a piece of Floran tubing. The smell of the Nelsonite and the speed with which it disintegrates gasket material is starting to make me leary of it, especially since I have been keeping it in my basement and can smell the fumes whenever I open the basement door.
Jim, thanks again for the gaskets. If I get the grapfoil tape to work, I'll let you know. Hopefully you have received the Nelsonite treated wood I sent you by now and can make good use of it.
Mike, if you get a chance to look at the Cue Components site, perhaps you could offer your opinion as to whether their Resolute is actually less toxic than Nelsonite. Inquiring minds would like to know.
