- Apr 19, 1999
Over the last four weeks I have had two separate belt manufacturers visit my shop with samples of a new belt configuration.
Both manufacturers were promoting a very stiff backing on their belts, much stiffer than the conventional Y weight belt. These belts do not roll over at the edge of the contact wheels but actually extend beyond the wheel and are stiff enough to grind with in the unsupported mode.
This stiffness allows me to grind the shoulder of the ricasso perfectly square and makes the matching of the shoulders a piece of cake.
Both manufacturers are supplying the belts in grits from 50 to 240 or better. This is a real benefit because most fine grit belts are available in J weight only.
The first manufacturer is VSM and their belt # is KK711Y, the second is Hermes and their # isSB378R.
You should be able to source them from your local distributors.
I get this information from time to time because of the commercial metal polishing shop that I own. I will pass anything new on as it comes my way.
george
george
