New additions
As short as the bevel is, it actually looks hollow, not convex. How did you do the grind?
@CagedSuperman those knives look nice, I did pretty much the same thing with the first couple knives I made, where I did a ridiculously thick convex grind. But I quickly learned that, that thick of a blade is not good for anything else but a prybar. Most people don’t realize just how thin you can make a knife that will hold up to hard use.
I regularly make knives with a very acute flat or slight hollow grind with a behind the edge thickness between 0.015“ and 0.020” depending on steel and use, if I need to go much over 0.020” with a steel to make it heavy duty enough for the task then I will select a different tougher steel.
One example, awhile ago I made a knife in 80crv2 that I heat treated in a gas forge (I know barf 🤮) stock was 3/16” with a nearly full flat grind, and about 0.018” behind the edge, I did some torture testing with it, including batoning through a brick as well as a cinder block, the damage did not go past the secondary bevel! and it wasn’t even heat treated correctly!! AND let’s be honest when in a real life scenario are you going to need to baton through a cinder block!!
Best regards,
Joseph
I use a gas forge. My 2 80’s are near unbreakable
Ignoring people just to read their posts anyway? Ok...
Well he had no reasonable feedback like others, so he’s not worth my time. I only viewed his stupid comment because I figured the ignore would not have my posts show up to him. Unfortunately there’s not a straight up block.
because it is 1/4in thick. At that thickness, most things are gonna be near unbreakable. What he was saying is with a proper HT you could be using much thinner stock and still have a near unbreakable blade, also one that cuts much better.
Precisely.
Your knives are...uh....well, they're something alright.
My feedback would be that you should probably look into a Knifemaker's level membership if you're going to continue to try to show off your work here. Other knifemakers have paid for the privilege to do so, after all.
Lol, no. I’ll learn. You’re more than welcome to have my account deleted.
Isn’t that rich
Why necro a thread like this? surely nothing positive can come from it. I got a lot of the same criticisms when I started making (I still forget to bring the bevels higher sometimes for my larger pieces lol), but I took it to heart and moved on to better my craft.
Rather than revive this negative thread, post some of your recent work in a new thread and compare the criticisms (you will always find some criticisms). I'm sure you will see your growth and be inspired to keep working!
