- Nov 13, 2004
Traded
Spyderco's participation on the Usual Suspect Network forum led to the creation of a very special, one of a kind knife, the Spyderco USN Endura4 in Toxic Green. This USN Endura4 is not only Toxic, but includes some of the most popular attributes found in the Endura4 lineup.
Introduction of the Endura with Emerson's opening feature; combining all that’s functional and performance-based in a Spyderco folder with the blade-opening feature made popular and patented by Ernest Emerson of Emerson Knives.
The Emerson opening feature is a hook curving out the top of the knife’s blade. When removing the knife from a front pocket it catches the pocket’s edge quickly opening the knife blade ready to use. The knife can also be taken out of the pocket without engaging the opening feature by pulling it straight up and out with your fingers on top of the closed blade.
The USN Endura also features all screw construction making cleaning and adjusting easier. Toxic Green fiberglass reinforced nylon handles are molded with Bi-Directional Texturing® for traction and improved ergonomics. Inside the handle dual skeletonized stainless steel liners strengthen the knife without additional weight and create an anchor for external and internal components to attach through for more sturdiness and rigidity.
The flat saber-ground CombinationEdge VG-10 blade is non-reflective, coated with black titanium carbonitride; includes a strong tip and larger 13mm opening hole. The front of the blade features the Usual Suspects logo. Added to the blade’s spine is slip resistant jimping. Phosphor bronze washers smooth out the open/close action and the clip is a four-way tip-up, tip-down, left- or right-handed clip.
Model # C10PSGRWBK
New in Box
Traded
NIB - SOG Micro Toolclip
Features full jaw pliers with grippers & wire cutters, spear point blade, serrated sheepsfoot blade, file w/screwdriver tip & wire stripper, & light duty pry bar.
Black polycarbonate handles with pocket/belt clip.
http://www.multitool.org/sog-tools/medium-tools/sog-micro-tool-clip.html
TRADE FOR: PE Spyderco's, PE Benchmade's, Peter Atwood tools, Leatherman Sideclip, Flair, Surefire LED's, #1 0n my list is a BM 610/615, Spyderco Endura with Glock tool.
ATWOOD IS Traded - August 16, 2009
NEW -Atwwod STEEL - G3 Prybaby with Stone Aged™ finish. Seven SAE wrench sizes : 1/4, 5/16, 3/8, 7/16, 1/2, 9/16 and 5/8". The insert cards state just six sizes - omitting the 5/8" size
NIB - Gray FRN - Endura Traded
Enduras with Emerson's opening feature have screw construction making cleaning and adjusting easier. Their gray fiberglass reinforced nylon ( FRN) handles are molded with Bi-Directional Texturing® for traction and improved ergonomics. Inside the handle dual skeletonized stainless steel liners strengthen the knife without additional weight and create an anchor for external and internal components to attach through for more sturdiness and rigidity. Their VG-10 blades are flat saber-ground with a stronger tip and larger 13mm opening hole. Added to the blade’s spine is slip resistant jimping. Phosphor bronze washers smooth out the open/close action and the clip is upgraded to a four-way tip-up, tip-down, left- or right-handed clip.
Traded
NIB - Spyderco Military Safety Orange ~ C36GOR - Plain edge
The 'Millie' has a modified clip-point blade laser cut with a 14 mm Spyderco Round Hole for quick deployment and for use with gloves. Jimping above the hole hold the thumb in contact with the blade's spine during cutting for confident control over the sharpened edge. The handle scales are Safety Orange G-10 with the lock's liner nested (inlayed) directly into the scale, pumping up lock strength without the addition of bulky liners. Spacers between the scales create a gap running the handle's full length exposing the inside workings for inspection and cleaning. The handle flares slightly at the front end creating a finger choil and at the butt end, which keeps the knife from slipping forward or backward in the hand while sawing or making tough or aggressive cuts. A contoured stainless metal clip is set for right-hand tip-down carry.
Traded
Top to Bottom - ( #1-5 Victorinox *** #6 - Wenger WatchMaker )
NEW 2005 Soldiers with Charles Elsener signature etched on blade #53929
[/B]
NEW 2008 Soldier #53929
NIB Final Production 2008 Soldier #53939
NIB First Production 2008 Soldier #54945
NIB Cadet ALOX # 53043 (TRADED)
NEW Wenger Watchmaker with plastic pouch #16922
Will trade for NIB SwissTool(s), NIB SOG PowerLock(s), NIB Paladin #540, NIB PE Spyderco(s)]
Model # C10PSGRWBK
New in Box
Traded
Traded
Traded
[/B]
