So far everyone I've shown the knife to loves it. They look at it skeptically, but when they get it in hand their eyes light up. I've had everyone from small hands to bear mitts hold it and all said it fits. The larger handed men said their pinky is right at the bottom of the grip, but it's still surprisingly comfortable. I myself generally do no like finger grooves on a knife, but these are well placed. They don't cause my fingers to fight for real-estate on the handle, and they actually settle the hand into a very comfortable grip that slants the hand slightly backwards while placing the thumb forward on the jimping pad. The blade is interesting too. It cants slightly inward, which makes the aggressive portion of the belly sit flush with the baseline of your grip. This makes slicing easy and allows a lot of force to be applied easily and surgically. The rest of the blade is slanted inward, which means your cuts pull into the blade instead of away from it, and cutting power is also increased. The blade is nice and thick, with a swedge that starts high on the blade. This makes the primary grind narrow towards the edge, finalizing in a thin but we'll supported cutting edge. Not as thin as a Delica, but enough for rugged use and easy slicing. The handle material is a very stiff frn. It has almost no give at all, so it doesn't need liners, further cutting down on weight. The triangle pattern on the scales work better than the Spyderco push/pull texture and feels excellent in the hand. The one piece lock is very interesting too. It works fantastic and all the parts are high polished. The smoothness can vary between models, so check them all before you buy (if possible) to find the best one. I'm sure they'll all break in just fine. I haven't taken it apart to see if it's on washers, but I assume it is. The choir is super small and only smaller hands can use it, however if you decide to use it you should definitely consider filing it down at 45deg to make it safe for use. Overall it's fantastic. Would live to see a model in CPM 154cm or s30v (NOT s35vn... So tired of that steel). Boker is gradually introducing better steels in their models, and this USA model is a total step in the right direction.
Sent from my 2PS64 using Tapatalk
