- Jun 29, 1999
Knife = cut. Ax = chop. Use the right tool for the job. And kudos to Mike Stewart & Bark River for honoring their warranty -- despite ill use.
knife = cut. Ax = chop. Use the right tool for the job. And kudos to mike stewart & bark river for honoring their warranty -- despite ill use.
the golok is not a compitition knife that is used under staged conditions.
The golok is a monster that will be mis-used more than used.
Ground too thin and run too hard. Typical BRKT problem. They make good stuff but when they err, that's the side they do it on.
They may have their RC listed with a specific number, but that number can vary. I don't care what they proclaim as the intended RC, they can end up too hard.
I'm curious as to how you were removing the blade as you chopped. I'm not accusing here, just asking. I've seen plenty of guys twist a blade side to side to get it loose, when they should be rocking it up and down. Just saying...
I've only used my Golok a bit, but never had a problem from any of my Barkies. My PSK, Golok, Bravo 1, and Mountain Man are all ground thin. None of them have had any issues, but I don't baton any of them nor expect them to chop the hardest woods.
Ground too thin, yes I agree here.
Run too hard?
RC 58 isn't harder than my Fällkniven NL's at RC 59 and they don't chip or roll, but they are thicker in the edge.
My Golok doesn't chip or roll with the new geometry and I have used it continously for hours of chopping Maple.
No I don't agree that it should be to hard.
Regards
Mikael
A thicker geometry and/or edge angle can compensate for high hardness, but I find that 55 RC is pretty much ideal for long, thin choppers. I think they run the blades dangerously hard for their intended work, and that's the reason why there have been so many threads identical to this one in the past several years. The new geometry you now have is fine for the hardness--the original geometry is not. Ground to thin for the hardness or run too hard for the thickness--they're equivalent terms. It all depends on what geometry you're shooting for.![]()
Yes I agree with You, the heat-treatment, geometry and the steel has to be on the right level for the intended use.
Many tools are made with RC 55 in order to not fail, but in a chopper that also is designed to work as a knife, RC 55 is very low.
For a Machete which is teamed with a smaller beltknife, RC 55 should work perfect.
Regards
Mikael
