- Aug 27, 2006
Follow-up to comments.
Limited Edition Boone and Crockett series with Paperstone scale
Those are the best looking Buck stockmen I've ever seen. What is the story behind them?
Made in the USA. Yellows are production line knives. The black sawcut is the standard bearer of the Buck slipjoint line. It changed slightly with the scale going from Delrin to Valox material. Did you know the knife,hammer and bolt shield is not a shield. It is a raised panel intergal with the liner, fits thru a scale hole and is stamped. Can't fall off because of glue faliure..... The Chariman series Cherrywood scales and the Dymondwood scale series share the same scale material just in different color. For 2010 both of the Cherrywood and Dymondwood lines will have the new 'Comfortcraft' rounded edge shapes. So will the Yellow series. The black sawcut Valox remains 'square' edged and the Limited Edition Boone and Crockett series also shares square edge shape and that LE series uses the new Paperstone scale material.
My dumb guy opinion would say that, if history is an indicator, after a few years one model is dropped to put another variation into production. (Only so much factory space) But the black sawcut has remained the standard bearer since the 1980's.....
Steel options, very seldom and few. Usually associated with Limited Editions. But be aware Buck now has its own laser blade cutter for production level output. Soooo lets hope for some standard production SV30 or even the Sandivic steels that they are using on other models.....
If anyone is ever at a knife show where the factory has a booth, stop and give the folks your opinion. You never know........300Bucks
I would kill for a Buck 301 in Sandvik 13C26 hardened to a 60HRC.
I think I would have "found my vorpal blade".
