- Feb 17, 2007
Well, I made it. Has a 1 hp 3phas and a TECO constant torge VFD. Has exchangeable heads and I went from a buffer to a disk setup it 30 seconds. You loosen up the knob on top slide the head in and remove the belt. Then remove the head. Then place in the other head, place the belt on and pull out on the head to tighten the belt and lock with the knob. Goes from about 60rpm to flat flying with the turn of the knob and reversed directions with the flip of a switch. I mounted it on a stand with locking casters. plus, the assembly rotates by moving the arm below it to loosen a 2" union nut, and then after you have it pointed the way you want locking it back down. Runs like a dream. Just have to wire in the foot petal now and make myself a couple more buffer shafts. Shafts are 1" turned to 3/4" for the bearing. Has drilled out 3/4: nuts with 1/4-29 set screws drilled and tapped on 3 flats so I can adjust them to put on as wide as buffer as I want and tighten up with a nylock nut. The buffer shaft is 24" end to end so plenty of room. The disk is only about 14" side to side and I have a 9" on the drive side and a 12 on the other. I am a happy camper with this unit.
I maybe making some more of these if there is any interest. This one was a proof of concept one and there will be some small improvements if I make more. Jim
Buffer
Disk
side view
swivel setup
Buffer head
Buffer
Disk
side view
swivel setup
Buffer head
