International Orders: Currently We do not ship or take payments from outside the 50 United States. We hope this will change in the future.
They dont accept emails from outside the 50 states either...
Check out the new CRKT pen designed by Elishewitz, the Tao. Cap fits on the end, MUCH better clip, Fisher refill also. When they hit the market, I will be in line waiting.
www.crkt.com
Lol, I think you and I are the only ones that saw that. Definitely wow. You don't see Hasselblads around a lot.
I have one of these and think it's the best of the so-called "tacticals".
Mil-Tac pen. They've improved the clip, mine has two screws. You can loosely post the cap when writing, although it can come off easily. You need the conversion piece (small plastic sleeve) to use Fisher cartridges. I use a blue bold point and it's awesome. Pretty simplistic and less threatening.
Tactical anything becomes known to law enforcement before it becomes known to most of us. Yes, you could see it taken away. Tac pens, kubotans, all of it.
On the other hand, an ordinary metal pen without grooves and flanges, or a mini maglight in lieu of a kubotan, will fly just fine.
The pen is actually well made. I' m hardly a machinist. But this unit appears to be milled out from bar stock. The fit and finish is excellent. The knurled rings on the body are clean and has more than enough grip onto your flesh to provide as a kubaton. The low profile matte frinished pocket clip is strong and is secured by 2 screws. The cap screws down about 1.5 turns. And is tight with ends mating almost perfect. There is no o- ring for water resist. The body seperates by about 5 turns to reveal a Fisher cartridge, which holds a minute 0- ring that rests on the lower step of the cartridge. This may help water resist capability. At least from the tip end. The cartridge stays put with no wiggle while writing. Mine came with a rather smooth ink flow- no globbing... so far. The cap does not and cannot rest on the butt end of the body. Both are the same diameter. This is a plus if you are contemplating impact/ locking weapon use- no clickie, no twisty for something to go wrong. For those who need to write on many seperate occasions thruout their daily routine, the non- capping cap may be a pain. But if you write for long sessions, especially if stationary at any area, I don' t think it would be a great inconvenience. The knurling location on both upper and lower body is just right for my hand. No slipping nor much need to reposition. The only marking on this pen is located on the opposite side of the pocket clip- "CAGE: 4QK35 MADE IN USA". I like this one. Nothing fancy. Just utilitarian low profile appearance and construction. Worth the $.
N.
www.dozierknives.com/forum
I got one of those and I like it a lot. That Mil-Tac and the Perrin pen are the only tacticals I carry.
