ha ha I started reading at the first posts and didn't look at the date .I know this is a super old thread, but I just found my old delica that I had stopped carrying and I forgot why (surprise, it was bc it's stiff to open). I tried everything above, and with nothing else to lose I just bent the lock bar spring with a little screwdriver (not as hard as you think) and it works great, now it's back in the rotation
If you , perhaps , worked a screw driver in there without first taking it apart then I would warn against that because what anchors the spring in the handle is a worryingly thin piece of fiber reinforced nylon and it would be easy to crack or break that off .I just bent the lock bar spring with a little screwdriver (not as hard as you think) and it works great
I probably bought one he made, the only cold steel I owned, a rajah III, I could actually shake out AND whip shut like an axis lock/ compression lock by pushing the lockbar with my index finger.He probably was failing to make the Cold Steels too hard to open AND CLOSE so they gave him the sack .
I can do that with my saber ground endura.I probably bought one he made, the only cold steel I owned, a rajah III, I could actually shake out AND whip shut like an axis lock/ compression lock by pushing the lockbar with my index finger.
