New EDC folder
I have been carrying a skyline for the past several years and just managed to lose it. I am in the market for a new blade
Over all, I liked the skyline a lot, but there were a few problems that I would like to see if I can avoid.
First, the blade was a tick thin, and I managed to flex and a later bend the blade ever so slightly doing pretty light work with it. I think I would like a slightly thicker bade or at least a slightly more rigid blade. I don't really pry with it, but some of the heavier cutting using the tip is what put the kink in it.
The other thing is that the shape of the handle wore a hole in all of my rear pockets pretty quickly. I carry it hinge up in the right rear pocket at the outside edge. That pointed handle wore right through the fabric of even my heavier carhartt pants.
I would really like an assisted opener this go. I had a Kershaw blackout that I like for that reason, but I lost it in the pasture somewhere.
I do like liner locks. I like a knife that has the clip way out at the tip so the knife sits as deeply in the pocket as possible.
Things I like about the Skyline:
Blade shape No more pointed than this one and if anything, more belly to the blade on the new one.
Ease of sharpening and good edge retention
Size (but I could be happier with a slightly larger knife, definitely no smaller)
Flatness for carry
Solid clip that held up until the end
Very inexpensive for the quality
clip position options. I would actually like to carry hinge down/point up on the new one. I just never got around to swapping the clip on the skyline to carry like that.
With these things in mind, what suggestions would you have for a replacement? My budget is flexible, but I do tend to really use a knife and sometimes lose them, so a $300 folder is out of the question. $100 is my upper limit unless it is something super special. For some reason I feel more comfortable spending more on a fixed blade than a folder.
Thanks for the help
PS. One I looked at was the Rake, but I do not see it locally available and never got to actually handle one.
Spyderco Delica, ZT0350 blem ($85ish), Benchmade Griptilian, Kershaw has a lot of options if you don't mind assisted opening--the Blur being a good one. Spyderco Manix 2 lightweight is a tough little folder as well.
I have a Rake I never use because I was never able to put a sharp edge on it. If you're skilled enough to sharpen it I could send it to you so you can try it out for a couple of weeks. If you decide to keep it we can work something out later.
What was the issue with sharpening? Personally, I usually use a gatco type sharpener system on my knives. Will that work with it?
I was really curious about the hybrid blades like that. Other than the sharpness issue, how does it feel?
Maybe a Spyderco Sage 1? Except for the A/O, it might fit the bill. Good knife.
Good luck, OP! :)
-Brett
If you don't mind aluminum handles, check out the Kershaw Knockout. The Kershaw Piston is a little bigger than the Knockout and has G10 handles. Worth a look as well.
Spyderco Sage 1 is a good choice too!
I recommend you buy a Spyderco Delica4 in whichever flavor you prefer. I have the Skyline also and like the Delica better. I have the model with the Emerson Opener.
Another choice is the Spyderco Sage 1. $106 at Amazon. On my wish list.:)
I admit that it's pretty amusing that a forum member named "Kershawguy13" is recommending Spyderco knives over any of a number of Kershaw products that would fit this guy's needs/stated wants perfectly. LOL
He wants a stronger blade than on the Skyline... a Delica or Sage probably won't do it. He is also looking for a bit larger, definitely not smaller.
I don't know what the problem is with sharpening the Rake, I use the Lansky with diamond stones and after hours couldn't get it sharp. I removed a lot of material to the point where the tip's bevel is almost to the line where the D2 ends. This was when I was still figuring the sharpening out, maybe I'll try again.
As far as suggesting another alternative, take a look at the Benchmade 710. It's a little over your budget if new, but maybe you could find a used one. I got mine used for $80 IIRC. It's not assisted but the Axis lock is quick and easy to operate.
Kershaw was my first knife so I will always like them; however I like Spyderco designs and knives better.
Wow Lots of good suggestions. The Piston is looking really promising.
I have always liked benchmade and spyderco knives, but never owned one.
I am a little surprised how much the Skyline cost has gone up. I bought mine at Bass Pro for $19 several years back.
Having owned a delica and currently owning a mini griptilian, a spyderco sage 1 and a small sebenza, I find myself to be in awe of the build quality and ergonomics of the sage 1. It simply can't be beat at that price and so I would suggest that you give it a try. It's a wonderful knife.
Yeah, the F&F on the Taichung Spydies is amazing.
As I have been looking, I found Spyderco stretch looked interesting. Unfortunately, not being able to see them, I wonder how people liked those and if it would fill the bill?
There are so many that look similar in a picture, that I am having a hard time differentiating them or finding differences that make or break a good EDC.
Thanks for all the help and suggestions so far
How about the Kershaw Thermite. I also like the Knockout too. Good Luck! Kevin :D
