- Feb 1, 2001
My new Strider RCC is built like a bank vault and rock solid but was about as sharp as a crow bar! They ground the edge pretty blunt and I decided to buy a Lansky sharpener to see if it would help get a nice 20 degree angle on it. I had to remove a lot of steel at the edge to thin it out and bring the bevel up a bunch.
I took my 3 hours per side but the Lansky did a good job and made a nice even bevel. Not sure how it happened but on one side of the blade the bevel is a little bit higher then the other side even though I used the same 20 degree angle.
The blade is now like a razor and will shave nicely! Here is a couple pictures before resharpening with the Lansky:
And here is how it turned out after using the Lansky:
I usually free hand sharpen but when I need to remove a lot of steel to fix and edge I like a guided sharpener so I can watch TV and not concentrate on holding the correct angle.
