- Jan 9, 2014
Below are our 3 mid-tech outdoor knives. We use CNC milling to help shape the knife and then do a lot of hand sanding and finishing, heat treating etc. on each one. We do everything in house including harvesting the wood for our Yew scales! For more info and photos or to purchase a knife visit our website. *A note to our american customers: the US dollar is currently a lot stronger than the Canadian dollar, which means approximately another 20% savings for you!*
All three knives are now available in 3 different surface finishes. CNC satin, Hand rubbed satin, and mirror. In combination with the different scale colors this makes for a lot of photos so I haven't posted them all here. There are photos of every combination on our website.
The Kermode is a fillet knife designed for the common game fish on BCs west coast: salmon, halibut and ling cod among others. It will work well for any fish but the blade length is especially suited to large fish. It also performs well as a boning knife. The blade is designed to have enough stiffness to give good feedback while being flexible and thin enough to cut excellent fillets. Scales are available in 4 colors of G10: Hunter Orange, Neon Green, Black and Royal Blue as well as western yew wood. Comes with a Kydex sheath; a belt loop (easily attachable with Chicago screws) is an optional extra.
Specs:
Blade steel: CPM S35VN
Blade hardness: HRC 58-60
Blade length: 8.8"
Over all length:14.3"
Blade thickness at spine: 0.062″
Cutting edge angle (inclusive): 20°
Weight
G10
knife only: 5.4 oz. (155 grams)
with sheath: 8.0 oz. (225 grams)
wood
knife only: 3.7 oz.
with sheath: 6.2 oz.
Made in BC, Canada
price (with blade forums 10% coupon:bfwinter15): CAD $139.50-$193.50 Depending on blade finish and scale choice
*approximate* USD conversion (dependent on exchange rate): 115-159
The Coho is an all purpose light to medium duty outdoor knife. The blade geometry is a nice balance between slicing ability and strength. Scales are available in two colors of G10: OD green and Hunter Orange as well as Western Yew wood. Comes with a left or right handed Kydex sheath.
Specs:
Blade length: 4.25" (10.8cm)
Over all length:8.5" (21.6 cm)
Blade thickness at spine: 0.100″ (2.54mm)
Cutting edge angle (inclusive): 25°
Weight
G10
knife only: 4.4 oz. (125 grams)
with sheath: 6.8 oz. (190 grams)
Yew
knife only : 3.4 oz. (95 grams)
with sheath: 5.6 oz. (160 grams)
Made in BC, Canada
price (with blade forums 10% coupon:bfwinter15): CAD $125.1-$152.10 Depending on blade finish and scale choice
*approximate* USD conversion (dependent on exchange rate):100-121
Osprey:
The osprey is the larger of our fixed blade outdoor knives, designed for heavier duty cutting tasks. A 5.5" blade and grippy handle give this knife great balance and hand feel. Scales are available in 3 colors of G10: Olive-Drab green and Hunter orange and camo as well as Western Yew wood. Comes with a left or right handed Kydex sheath.
Specs:
Blade length (tip to handle): 5.5″ (14cm)
Over all length:10" (25.4cm)
Blade thickness at spine: 0.138″ (3.5mm)
Cutting edge angle (inclusive): 30°
Weight:
G10
knife: 5.4 oz. (155 grams)
with sheath: 8.2 oz. (235 grams)
Yew
knife: 4.8 oz. (130 grams)
with sheath: 7.6 oz. (215 grams)
Made in BC, Canada
price (with blade forums 10% coupon:bfspring15): CAD $152.10-179.10 Depending on blade finish and scale choice
*approximate* USD conversion (dependent on exchange rate): 121-143
Specs:
Blade length: 8.8"
Weight
G10
wood
knife only: 3.7 oz.
Made in BC, Canada
Specs:
Weight
G10
Yew
Made in BC, Canada
Osprey:
Specs:
Weight:
G10
Yew
Made in BC, Canada
