- Dec 3, 1999
Here's something I threw together in the past couple days.
I LOVE my filing guides from Uncle Al... but I make really short ricassos on almost all of my knives. Even though my ricassos are always surface ground (so they DO have flat/parallel sides) my filing guides usually don't want to clamp down on the blades and be completely flat across the top.
I've had this idea for a long time, but just finally made it happen. I sketched something like this out about 10 years ago... but I'm certainly not the only one to come up with something like it. Uncle Al actually has a very similar rig on his site! :foot:
Anyone could build this. It's very simple... but effective. It would have been faster/easier to start with clean steel... but I try to use what I have.
The jist of this thing... is the you clamp the blade down with the area you want to file sticking out through a piece of hardened steel plate. In this case, it's 3V that I fully hardened and didn't draw back.
(about 63-64 Rc). Since you're filing against a small plate, it can't be anything but flat. With a couple of set screws in the main block, you can persuade the blade a little (if needed) to make sure the blade is square to the guide face.
I used my surface grinder, drill press, and did two milling steps... squaring the end of the block, and making the slot in the face plate. If you don't have a mill, you could drill/file the slot, and give your buddy with a mill a dough-nut to square the end of the block.
