I'm new to the forum, and Busse Combat products. I have been reading as much as possible over the last few weeks, and I am getting close to making a decision on which Busse to go with, but I have some questions first. Now, my intent is not for this to be a "pick a knife for me" thread, but any suggestions along those lines will be welcomed.
So far, I have focused mainly on Satin Jack Tac (CG?) and now the ASH1 models, but there seems to be a few variations to choose from. My intended purpose for this knife is a general use knife in the field, but with the primary purpose being my pending deployment (USMC 0311).
Most of the models I have been seeing for sale (in my price range) are 3/16 (.187") thick.
Between the two mentioned (ASH1 and SJ Tac) is there a discernible advantage in utility?
Can both be safely used for chopping, splitting wood (using a rock/hammer)?
Does a .25" blade have an advantage over the thinner .187 ones? Such as prying. While I understand a knife is not intended to be used as a prybar, I am buying this to take overseas, first and foremost. Getting a great field/survival knife is just a pleasant result, and while it may be calming down "over there," it may heat up. So, I want the knife that can take any possible abuse. If I need to use my knife to pry open a door, I'm going to do it. If the thicker one is noticeably better for this purpose, let me know.
Next, about variations/grades.
What exactly distinguishes a blade as Combat Grade vs others?
Is it a thickness thing or what? Like with the Satin Jacks. According to hogcult.com, there is the SJ CG at .25, the SJ TAC CJ at .187, and the SJ TAC LE at .22. So what do the TAC, CG, and LE actually indicate. Is it more of a way of simply keeping the models separate, or is there a method to the madness that I am missing?
Thank you in advance for your time and expertise,
John
John
