- Sep 10, 2000
Those are all fine machines, but I once again recommend a very close look at that T-90
. You can get the surface grinder atatchment later.
Frank
Frank
I got a KMG about 7 months ago. I haven't had any issues with it but don't use it every day. What have been the issues you have ran into that I should be aware of?At this point, the KMG design is probably up for a re-think. There are tons of new designs that are comparably priced, built better, and offer more versatility and features. Also, they likely have better customer service. My KMG has been nothing but a headache, and since offering a fix for some of the issues I've heard from tons of folks complaining of similar issues. I think, if you manage to get a good machine, you're good to go, and it'll be a battleship. If you don't... well, I hope you're good at creative thinking and problem solving, because you'll be on your own to correct things.
I can't stress this enough - find people that have grinders, and see if they'll get you time behind them. Get some experience!!! Find out what the owners like and don't like.
If I had the money, the TW-90 is still my current 'most wanted'
I'm eying the Northridge machine, too. I saw it at Blade last year, but I don't think their setup was secure enough to properly demonstrate it, so I'm going to try and give them another look.
Wilmont's grinders appear to be well received, as does the Esteem grinder. I have very limited space in my shop, though, so if a machine isn't capable of swinging horizontally, it doesn't make my list.
Drew Riley's machine (ARCustomKnives here on BF) looks to be a sweet device, as well.
I've never heard anyone complain about Bader machines, and their customer service is top notch.
My observations are merely my observations, btw. I'm hardly an expert at any of this shit, I just know what I've seen and what I like, or don't like. Good luck! Hope this helps.
Sent from my XT1254 using Tapatalk
Matthew, thank you for that information that is very helpful.There have been a variety of issues, but I'll bet a quick search of "KMG" and "vibration" will turn up results. I had a lot of issues, but the biggest one was horrific vibration due to the pulleys. A friend of mine made a direct drive conversion kit for me, and he's sold quite a few to guys looking with similar issues.
Here's my thread about it:
http://www.bladeforums.com/forums/showthread.php/1351035-Converting-a-KMG-to-direct-drive
Matthew, I would say that you ARE an expert on KMG grinders considering all of the modifications and adjustments you made to your KMG. In my not so humble opinion the biggest problem with the KMG is the lack of a second tool arm slot followed by it using belts and pulleys rather than direct drive, and having a poor tension spring arrangement rather than a gas piston for belt tension. The tracking adjustment wheel is too small and the tracking arm needs a longer lever. I copied most of the mods that Matt made on his grinder and improved my grinder to the point that I prefer using it to my other newer grinder. If I had it to do over again I would look closely at the Wilmont and the Travis Wuertz TW-90. It is kind of satisfying though to make improvements to your equipment. Just my opinion again. LarryAt this point, the KMG design is probably up for a re-think. There are tons of new designs that are comparably priced, built better, and offer more versatility and features. Also, they likely have better customer service. My KMG has been nothing but a headache, and since offering a fix for some of the issues I've heard from tons of folks complaining of similar issues. I think, if you manage to get a good machine, you're good to go, and it'll be a battleship. If you don't... well, I hope you're good at creative thinking and problem solving, because you'll be on your own to correct things.
