New knife maker - blade thickness question
I am hoping to get some advice. I am a new hobbyist knife maker. These knives will be primarily hunting knives for gutting and skinning. I am looking at material either 1/8th or maybe thinner at 3/32. 1/8th seems common for some of the store bought knives I have but I have a couple 3/32 blades that people made for me and the thinner material seems to sharpen easier. I welcome any opinions and thoughts on this. I am probably going to use either 440C or D2 as I can get the material locally and also get it heat treated at the same place.
Thanks
Depends a lot on your geometry & grind. I have a Hess Pioneer in Full flat. It is almost scary sharp. Lots of belly and a point. It is 1/8th. But it carries a blade height of inch and an eigth. So there is plenty of time to taper from 1/8th down to a lazer sharp edge. While still maintaining some overall strength.
The Hess Muley shown here is also 1/8th thick, also in full flat, With a blade height of approximately 7/8s of an inch. Still plenty of real estate to taper to a fine working edge for critter work. And again enough inherent strength for camp chores.
A saber, scandi, or hollow grind will change your specs drastically. As would blade height.
I think 1/8th inch is a reasonable starting point. The thinner stock might not be as forgiving, if you need to adjust for learning.
Hope this helps ya, and good luck!
Neither are overly thick blade stock. I'd guess the 1/8" would work well enough for more tasks. 3/32" would make a great slicer (if ground right) and be more ideal for most light duty tasks. The debate would be more task capable or better at a limited number of tasks. That's all individual. 1/8" isn't too thick though for most uses and would be a safer bet as a less specialized blade.
The big question you'll have to ask yourself about what works best or what sells best.
Thicker knives tend to sell better. Thinner knives (at least for skinning) work better.
