- Dec 25, 2014
Hey guys I'm working on my first knife and need some help. Everything has gone well so far (I think) until I got to the heat treat. So i did the quenching and then put my knife in the oven at 500° F (I'm doing 2 heat treats at 500° for 2 hours each). The temperature stayed at 500° for the first half hour then started to drop down to around 450° (I'm using a toaster oven and it was at max so no just turning it up a bit). As soon as I saw it drop below 500° I pre heat the oven to 500°, it took about half an hour for it to reach that temperature but as soon as it did I switched over to the oven. My question is will that dip in temperature for a while effect my heat treat? Or will it all be OK because I'm doing a second time in the oven?
The steel I'm using is 1084
For quenching I brought it just above non magnetic then quenched in canola oil.
Thanks in advance
Forest Howland
Thanks in advance
Forest Howland
