Hey everyone,
I just started learning and trying my hand at knife making. I'm new to this but do a lot of wood and metal work. I ended up with some end cut pieces of maple and walnut from a different project and decided to glue them up and make a knife handle. I used 3 pieces of walnut with two pieces of maple and thin brass strips as spacers in between. I rough sanded the brass for good adhesion and glued everything up with devcon 2 ton epoxy. After gluing I clamped the piece very tight and let cure for 24 hrs. Once set i through it on the belt sander to shape into a block. Problem is, as I sand and the wood and brass heat up the pieces just come apart. I have glued this up 3 times now, sanding the brass a little rougher and even making some small holes through it. but each time it separates while sanding. I know people make and sand handles like this so I know I'm doing something stupid.
I'm sure someone can point out what I'm getting wrong. Thanks in advance for any help!
