I am making a Musso Bowie . This knife ,do to it's size and shape ,would be a nightmare for even an expert .
It will be made from w2 . Even though I am a welder and fabricator ,I wouldn't dream of such a task . Because of the tapers and the amount of metal removed ,that knife would be chanting " " WARP , WARP ,WARP , " as it was headed to the oven to be hardened . So I called our waterjet guy . I will have the stick of w2 hardened and tempered . The waterjet guy will cut the blank ,set the knife on edge and cut distal taper as well as the bevels . I looked at the stickies ,I am still confused .Our water jet man needs to know the main bevel angle ,the height of the secondary bevel and it's angle ,or should I just do a flat grind ?
The distal taper will start out at 7/32 and taper to 3/16 . Should I taper the clip from 3/16 all the way out or should there be another distal taper before the point .
The tang will be flat ,but tapered in 4 directions . The handle will be cut out by water jet ,then it will be set up on end and the hole for the tang will be cut to match the tang . The fuller will be cut to match the handle ! Plus the cut man says the cuts will be so smooth it won't need any sanding ! Plus It will be done in a day !
Before this gets started I have to give this info to the cut man . I am real excited to get this project started . Any help would be so appreciated thank you
