Hello everyone,
I'm excited to be a part of this forum and looking forward to learning and participating in the future. I've already spent hours browsing and have found the knowledge here invaluable. That said I have a few questions on my first build. I've provided a few links to give a visual for part of what I'm inquiring about.
http://i201.photobucket.com/albums/aa45/wowndeye/Mobile Uploads/20140419_144549.jpg
http://i201.photobucket.com/albums/aa45/wowndeye/Mobile Uploads/20140419_144527.jpg
http://i201.photobucket.com/albums/aa45/wowndeye/Mobile Uploads/20140419_144806.jpg
So to start, I purchased some 1080 1/8 x 1 1/2 stock from Kelly Cupples (great guy BTW) and am starting with a "Drop Point Hunter" or at least some variation of it (not sure what qualifies as a legitimate DPH. Overall length is 7 3/8" and blade length is 3 5/8" He told me I didn't need to anneal it as it was hot rolled, picked and oiled so it should be about 28-30 on the Rockwell scale. I annealed it anyways just to give it a shot and see what kind of difference it would make in the steel. I drew on my template, rough cut the blank out with my angle grinder and Dremel then used my 1x30 to start cleaning up the edges. Dialed everything in and then started my grind for the blade. Got that to where I wanted and then planned on cleaning off all the scale with some wet/dry 220, but it's been a pain in the butt and I'm noticing some small pitting in the blade. Is that normal?
From this point my thought was to dial in the ricasso, get the blade dialed in where I want it w/ 220, normalize 3 times and then do the final heat treat for the blade. Should I just heat treat the blade edge or whole blade? I figured there would be more scale so why try and take it all off now. Am I on the right track? Any advise for dealing with the scale? Do I just need to sand really hard?
Also I'm using mahogany for my handle and want a durable finish for outdoors that brings out the color. Any advise? And how thick should the handle be at the thickest? It has approximately a one inch depth. I've got huge hands so don't know what's "normal"!
Thanks in advance!
Josh
Thanks in advance!
Josh
