- Apr 19, 2021
A strop could work but may take to much time. I use 1500 grit paper. If you don't want to buy 1500 try stropping on some cereal box cardboard with compound on a hard surface. that would be faster than leather. I don't mess with the rear face or the blade tang as that has never been the issue in my knives. I lay the paper on a table and lightly sweep the tooth in the vertical orientation following its curvature. you don't need to remove all of the grind lines, but you can, then polish it a little. Another area that can use a little smoothing is the detent area of the blade tang. To test, open and close the blade very slowly back and forth off the detent and feel for grit. The lock bar leaves a small mark on the detent area of the tang, smooth that little area and your golden. These are factory finished knives, you'll have to do the finishing if you want the best action.
