Greeting All,
I got my first MT, an LCC M/A (plain edge, Stonewash) on Friday (thanks Earl @ GP Knives) an it's truly one fine knife!
All the hype I've read is true. The lock-up is near perfect, with the liner making full contact with the tang. I've noticed that I can change the amount the liner engages the tang by rotating the pivot stud and re-tightening. I've also polished and glass beaded all the hardware and pocket clip (gives a more silvery-satin look as opposed to flat gray) and polished the bolsters with 400 grit emery paper to remove all the tool marks, then scotch-brighted and #0000 steel wooled 'em. I got a nice satin/brushed look. Question, how does one remove the thumb studs, without damaging them. I'd like to glass bead them also. I put a 30-degree edge on the blade. Any others put such a shallow edge on their LCC's with good results? I haven't used the knife hard yet, and I'll keep a close eye to see how well the edge holds up. FYI, the blade checks in at 61.5RC on an industrial Rockwell tester.
Russ (diggin his new LCC
edit: change 62.5 R/C to 61.5 R/C
[This message has been edited by Bertrand (edited 03-05-2001).]
