- Sep 22, 2023
Ya gotta wonder, which will be the biggest seller during the final 1/4, and the holiday season.
Good point.All of the patents ran out on the Wave and their other models. That's why they introduced the Free series a few years back. It's a newer set of patents. It's also why we've been seeing all these cheap Wave clones coming out of China. All of Leatherman's exclusive rights to their older designs ran out, so now anyone can use them. That's not the case with the Free series and the Arc, so it makes sense for Leatherman to push those as much as possible.
Some of the assertions here are ridiculous. Do you have any information that says for a fact leatherman intentionally changed the design to cause failure of inserts? I doubt that. People make design changes that in theory look good, people are wrong, and corrections get made. The sky isn't falling and leatherman isn't grenading as a company. I have an arc, it's fine. I swapped the inserts from a p2 in the arc, and the gap was gone. Easy fix that if I had to wager on, leatherman will make right.PSA
There are now multiple videos on youtube showcasing a design flaw with the replaceable wire cutters which ship with the Leatherman Arc.
The wire cutters included with the Arc have been redesigned so that they have a small gap at the base of the pliers. These newly redesigned cutters have a very high tendency to break when used to cut hard wire, coat hangers, or small thin nails. The older replaceable wire cutters do not have the same issue and will happily cut the aforementioned items without any trouble.
If Leatherman intentionally did this in order to sell more replaceable wire cutters, then the problem may never be fixed.
As a workaround, you can swap the replaceable wire cutters from older Leatherman pliers to the Arc. Anything made before 2022 should work and won't have the same issue. Going forward, it appears that all Leatherman pliers with replaceable cutters will have the same tendency to break. In other words, this issue is not restricted to the Arc. It theoretically affects all Leatherman models from 2022 onward, but anything before 2022 should be fine.
To check whether your pliers have this issue, simply examine the replaceable wire cutters for a gap at the base of the pliers when they are closed. The old style replaceable cutters have either no gap or a very tiny gap that is almost unnoticeable. The newer redesigned replaceable cutters which break easily have a noticeable gap at the base of the pliers when they are closed. The cutters themselves are also rounded at the bottom, whereas the older style are not rounded at the bottom.
I think them switching from 154cm to 440c for cutter material is interesting, but if both geometry are identical I'm not sure we'd see a difference in performance. Yet to be seen.
I have also been seeing several different QC issues. For 230 usd they probably should have better quality control. In some places it's significantly more expensive. I suppose they bet on making their money with super high volume, and that probably meant that the QC would suffer. Now that the issue with the cutters has come up, I wonder how they are going to handle it. They may just choose to ignore it and then quietly update the replaceable cutter design without saying anything.
If they really want to make money with high volume then they ought to release a non-magnacut version of the ARC without the bit kit and without the sheath. No thumb stud would be great too because they could just use the regular blade from the Free series with the thumb slot. That should cut the cost significantly.
If they made a bladeless version I think that would be pretty neat. They could just have the saw and the file on one side and nothing on the other side. Or they could have the scissors and the saw, or the scissors and the file. Or maybe have a knife and scissors on one side and a t-shank adapter as one of the shorter side tools.
You're posts are filled with more "i suppose" and "if" assumptions than a philosophers personal journal.Sorry for the confusion. If you look carefully, you'll notice that I didn't actually claim that Leatherman did this to intentionally cause failure of the replaceable cutters. I only speculated that IF they did this intentionally towards that end, THEN I think it's not likely that we would see them fix it. Companies doing that sort of thing is not unheard of. Again, this is just speculation, and we won't really know until someone from Leatherman publicly addresses the issue and gives an official reason for the redesigned cutters. Please carefully re-examine my post. It was not my intention to offend anyone who is a fan of Leatherman, nor do I think that I ever implied that "the sky is falling" or Leatherman is "grenading as a company".
On a separate note...
It's been suggested by multiple people that the new cutter geometry has nothing to do with them breaking. It could just be a bad heat treat of the cutters or something like that. Perhaps it's even due to a change in the material of the cutters. The newer style cutter geometry is inferior in my opinion because it doesn't fully cut unless you carefully position the wire above where the gap is. I think the geometry should be switched back to the old style without the gap, regardless of whether or not they are able to fix the breaking issue without changing the geometry.
Nothing personal about it at all. When someone makes up some random unsubstantiated theory and runs with it publicly, getting called on it is pretty normal as well.Speculation and hypothesis are pretty normal in any topic when there are unknowns involved. If your issue is personal then there is nothing I can do to help. Cheers.
So you defamed them without any established facts using rumors and internet gab on what might could be a handful of units that slipped through out of thousands of units. If you have actually experienced it with your own Arc that’s one thing but to make an accusation from other accusers who might not even have an Arc that’s another thing. What if those claims were made by bot’s hired by Leathermans competitors ?Speculation and hypothesis are pretty normal in any topic when there are unknowns involved. If your issue is personal then there is nothing I can do to help. Cheers.
