Yes or high alloy steels that do not need to reach 66 Rc. They typically have 0.7% or less carbon, usually 0.6% or less. And high temperature tempering can help with excessive retained austenite. Steels like Z-Tuff but with more carbide could be designed.So, Nickel makes most sense in steels at or below the euctoid point, to help avoid the retained austenite issue.
A super important resource for the edge tool world ! ! !
Thank you VERY much !
. . . er . . . I hesitate to even ask . . . er . . .
What about M4 ?
Is it so close to M2 in appearance that it isn't worth including ? You know I have M4 on the brain (and mostly always in the pocket)
. . . and it would be interesting for me to see S30V next to S35VN.
My opinion / knowledge of these two seems to be constantly changing.
I wasn't so interested in my knives with S35VN until I started using the Ranch Boss that I just got and it seems superior to my other examples in edge durability and right up there with HAP40 though I haven't used it long enough to say for sure.
Always somebody "complaining" right
Thank you sooooo much for this work Larrin !
PS : fascinating to see N690 ! ! !
Probably the steel that has surprised me most from what I expected (I expected a little better H1 and got a brother to XHP !) .
I do 42 steels and your first question is why I didn't do one more. There is a micrograph of CPM M4 in this thesis: https://ir.library.oregonstate.edu/downloads/8g84mp812?locale=enIs it so close to M2 in appearance that it isn't worth including ? You know I have M4 on the brain (and mostly always in the pocket)![]()
Myyyyyyy heroM4 samples are heat treated, awaiting surface grinding. High and low temper samples have been done.
You should try M42 , it s mother and father to M2 and M4
I think you mean child.You should try M42 , it s mother and father to M2 and M4![]()
That Stuartsmelt thoughHere is one of the micrographs of CPM M4 from the PDF Larrin linked to. CPM M4 austenitized at 2100°F, tempered 1025°F.
Oh, wait a minute, that's not right. That is the micrograph of a proprietary alloy I am working on called "Stuartsmelt". Here is the CPM M4:
