Is that a good thing?
Of course, ease of disassembly and maintenanceIs that a good thing?
Definitely a good thing, hope the PM2 gets this soon as well. Its like walking a tightrope to get the right balance of pivot screw tension and stop pin tension.
I personally have to respectfully disagree. I like the screw down construction on the stop pin as I feel it gives extra support to the pivot in reducing side to side play. In my experience knives that don't have a standoff or stop pin screwed down near the pivot have more issues with the pivot loosening. With the Pm2 a little washer sanding and you can get the exact tension you like. In some you can tighten the stop pin more. In others just sand the washers a little and you can get it exactly where you want.
A very good upgrade, no stop pin should have to have all the impact of possible openings or chopping/cutting pressure hitting a stop pin held by threaded screws. From an engineering standpoint it makes much more sense in having that impact distributed through a rounded contact surface. Take a look at all Cold Steel knives where the tang has a rounded cut-out that wraps around the stop pin for impact, that's why you never see flat spots or get vertical play in their knives. The only thing i think they should have done to make it 100% perfect is make the liner cutout wrap around the "stepped" part of the new stop pin instead of wrap around the thick part, if it rested on the shoulder of the thinner part of the in it would give the support sideways for hard squeezing of the handle also. Either way, a great upgrade to a long time classic.
Never understood this interpretation. Can you quote the exact text in their warranty statement that implies this?Glenn056, weird for ease of cleaning as spyderco doesn't allow for user disassembly without a loss of lifetime warranty.
I like being able to adjust the stop pin tension with a screw as well as the pivot tension.
right from their website.. cut and pasted...
Repairs to your knife performed by any source other than Spyderco Inc. unconditionally voids the knifes warranty.
Spydercos warranty does not cover damage caused by abuse, misuse, loss, improper handling, alterations, accident, neglect, disassembly, or improper sharpening.
so disassemble the knife and warranty is potentially void. course spyderco makes that call, but its well known they frown on disassembly.
