New (old) tool. Future shield inlet machine.
ron_m80
Tempered Member
If anyone knows what this is, I'd be happy to hear what you think. It's some kind of duplicator. Guide rod on the right, and mini end mill on the left.
I don't think that's a guide rod. I believe it limits downward travel.
The machine appears to be a miniature milling/routing machine. It's very cool!
It will do both, later on. It does ride inside a template of some kind, which I think will trace a few shield templates. Its too big for a complex shield at the moment, and so is the end mill @2.5mm
I guess I could explain it better...
The table moves X and Y manually by the handle on the front. The quil moves the pin on the right and the end mill up and down together. The bottom block is a double vice, left/ right sides.
I don't know what else it would be used for except inletting. I think its cool too, thank you. I just happened to see it in the small shop of a hardware store that is going out of business near me.
I would love to have it! I would think if you could get it cheap, you should.
Yep is a 1/1 ratio pantograph. It could be used for inletting shields with the only limitation by the endmill diameter.
Nice little machine
I "googled" it a bit this weekend. It is some kind of key cutting mill. I ditched the small vice block, and cleaned it up a bit. I need to get a new drive belt and set up a tool plate to lock down the work and templates for shields. I got this just in time for some Sambar stag handles I ordered.
Yes I have seen a machine like that in use at a place where i used to work.
It is to duplicate keys, the kind with round dimples in the sides
