What work did you do on your 9/10 to have them opening so easy,..
Thanks for all the replies guys
Thanks a bunch, some or all of these mods are my next project, until I have time I'm going to carry this no8 and use it to cut a bunch of stuffThe swinging open blade is best on the 9, 10, and 12 because of the length of their blades. They're still light knives, but the 8 remains for me a two hander. But you can do this with an 8, too.
First, it helps to live in a drier climate. No doubt if I were back in the SE or the PNW, the wood would swell and limit their movement. But even if you live in a humid place, it's still possible and easy to accomplish.
1. You remove the locking ring by closing the knife and locking it shut, then slowly opening the blade which forces the ring off the end. Point it where you want it to go, as it can fly off with an M1-like ping. Or do it under a dish towel
2. With a center lunch or a 10d nail, drive the pivot pin out one side of the ferrule. This will destroy the peening on the side you're striking, but no matter. The locking ring will keep the pin in place once you put it back on.
3. Remove the pivot pin. Slide the ferrule off. Don't lose them.
4. With a light to medium grit sandpaper, sand the inside of the slot where the blade tang rotates. Go slow. Remove some wood, then reassemble enough of the knife to get an idea of how loose it will be.
5. Another way the knife may be tightened or loosened: Pry open or pinch closed the width of the locking ring and/or the ferrule collar. Once the pivot pin is free from one of the peened ends, the ferrule collar can be adjusted.
I know this seems like a lot of trouble for a $10 knife, but it's a lot of fun to tinker with Opinels. If there were an adjustable Opinel style knife, it would be at least $50, heavier, not rustic, and not the same fun. If you like, I'll post some pics of my N°10 disassembled and a link to a video of a Japanese gentleman performing this process.
My last point: I have never had any luck using lubricant to loosen up an Opinel. The wood just sucks up the substance and never frees up the blade.
OK, another last point: My 10 and 12 don't open as effortlessly as the one in this fellow's vid. Mine take a bit of wrist action to sling them open, but that's partly due to the humidity this Spring and it doesn't bother me a bit.
Zieg
Edit: The video I mentioned is
No it isn't. Treat it like a friction folder without the security of the elongated tang that friction folders usually have. Because that is what it will be. Personally I wouldn't use an Opinel as a friction folder. I'm wary of FF's as it is and using an Opinel as one leaves no margin at all against Murphy with a blade that cuts like a light saber. Any mistake and you really will be looking for a new finger.You don't have to lock it. Locks don't matter. Treat it like a slip joint. That's basically what it really is.
This is off topic, but how durable are Opinel knives? I have never owned or even handled one before, it doesn't look like it would hold up real well if used much.
What it does look from the pictures is that yours does not fully open to 180º. I had one that did the same thing. A bit of file work at the back of the blade (90º corner) were the blade makes contact with the ferrule fixed that. Now the locking ring engages way better and the blade opens just like I want it to.
Mikel
Agreed, thanks for pointing it out. My locking ring wouldn't turn 1/8th of a turn before I filed it down. Now it does go a bit more while still being plenty safe.Mikel's locking ring might not have turned far enough while on my 12 it was already turning too far before I altered it.
Zieg
Mikel
