Ditch_Digger
BANNED
- Apr 5, 2009
Sorry but you are wrong again. This is taken directly from CRK site:
"Put oil on the areas where the washers go, and inside the pivot area. Also put some oil on the tang where the lock bar normally engages."
You can find that information here:
CRK site
I'm not wrong about sh|t but there's obviously a "difference of opinion"!
Adding "lube" to ANY area other than the the pivot bushing/washers only attracts dirt and grit. Why on earth would you want that in such a critical location??? During break-in, YES, but not after that! Maybe this is a moot point for all of the mall ninjas/keyboard warriors/collectors? Yes, surely that must be it. I can understand this excessive lubrication if your knife never gets dirty. LOL As my username suggests, I GET DIRTY (and everything on my person).
..and that link is a perfect example on how to EXCESSIVELY GOOP UP your Sebenza/CRK. Nearly all of the extra lube will simply squish out and attract dirt/grit. I'm frankly shocked to see such a poor example on Chris' site! I've never seen that before but thanks for posting it.
Since I'm thinking about this and taking the time to share a bit of my lifetime with sharp pointy things with my fellow enthusiasts...
If you haven't figured out that "excess" lube does nothing but attract things you don't want on your knife, try this experiment. Take you favorite slippie or any other older knife you have had time to carry/break-in and blast that sucker with brake/carburetor cleaner or some other aerosol de-greaser. Then air-blow it clean/dry. Do nothing but put it in your pocket and carry it for a month. Notice how clean it stays? Sure, it will still get some lint on it, but a quick blow from your breath is all it takes to knock off the fuzzies! A well made, precision joint, combined with a properly hardened wear surface needs very little lubrication, that's why the surfaces are "hardened". They will polish themselves and only get better with age. Adding dirt/grit attracted by oil literally "gums up the works". I know that sounds crazy if you haven't thought about it or had the benefit of years of carry.
*important caveat* THIS ONLY APPLIES to modern knives made w/ Stainless Steel blades and other parts that aren't prone to corrosion such as Titanium. Carbon steel will rust in a hurry without oil and this is where many people start their knife collection and form the habit of keeping everything drenched in oil.
