I've tried leaning a diamond bench stone against one of the ceramic rods, as other have suggested, but found it to be very awkward at best. I have, however, had very good success recently using a diamond rod in the 204's base. Here's the deal...
A friend had given me a Chef's Choice Edge Crafter pocket diamond steel (medium grit). This is a retractable rod, approximately 3/16" diameter with about 4" of usable surface, in a brass sleeve with pocket clip.
Anyway, if you look into the 204's base you will find that there are round holes at the bottom of each stone opening. I removed the diamond steel from the brass sleeve and tried fitting it to these round holes. It fit with some play in the round hole itself but, when the steel is allowed to rest against the side of the stone cutout, the play is eliminated.
Although the resulting angle may not be an exact match to that of the ceramic stones, I found that it is close enough to allow me to use it for reprofiling. To date, I have used this method to reprofile the edges on 4 khukuris (5160 steel, hardened to 57-60 RC or so, 8-12"+ blades). It may be there but I couldn't detect a difference in sharpening angle when switching over to the ceramic stones. Of course, YMMV.
FWIW, I did experience a loss of some diamonds from the steel when using this method. Frankly, in light of the time it saved me & the excellent results I achieved, I don't care. There is still life left in the steel & I'll simply replace it if & when necessary.
