- Apr 3, 2013
I was sent 2 new Venev stones from Konstantin of Gritomatic for testing,they are 1200 FEPA grit or 6K grit jis rated stones.
There are a few thing's Venev is trying to achieve from what I was told with these new stones.
They are trying to make a more stable bonding material that holds the diamonds in place and also they are trying to achieve a better scratch pattern that is better for polished edge's.
The other thing I was told is that at the 1 to 3 micron level of the original bonding material it can compress when stored over time and bend the aluminum blank and that is why Venev is trying to make a more stable bonding material.
Here are some pictures of the 2 stones I got from Konstantin,the top picture is a DLT Trading Mini Griptilian exclusive I got a while back and it has M390 blade steel,I also used only Venev stones on both knives and started with a 150,400,800,then I switched to the new Venev stones I got witch would be 1200 FEPA grit or 6K as I stated before,I did no stropping at all I only used stones as I was asked to do and take pictures of the result's.
I also want to say thank you to Venev and Konstantin for sending me these stones to test.
I used the 1200 grit stone marked OCK on the M390 blade.
Here is a picture of the OCB stone after I sharpened a Spyderco Paramilitary 2 the same way I described above.
Here are picture's of the stones they are more greenish in color like cement that has not fully cured and is still a bit green.
