The Sebenza is the single finest crafted, precision made production knife, period. It has this "issue" too, when new. Keep working the action, and it'll break in.
Reeek / Planterz, you guys nailed it. Pivot adjust / slab loosening solved the centering issue; she's dead nuts now. Though, it's quite a bit tougher to open and close since. If I loosen the pivot too much it slides back out of center. If I tighten it too much, the lock barely engages. I think I've got her where she needs to be but the action is really stiff both ways. Lube / oil and play with it now? :jerkit:
I hope I didn't turn anyone off to the knife, I guess when the hype and anticipation reaches almost "grail" proportions, the expectations are high.
Anyway, I'm feeling much better. Thanks fellas!
Webb_Jr
I may open mine up and re-lube with CRK grease. I don't usually use that on other company's folders, but it was an amazing upgrade for my Gayle Bradley, and it might be a good choice here, too.
My Sage 2 had the same grinding/scraping sound and feel.
After 50 or so openings the ball bearing had worn a slight groove/track in the blade and is now very smooth opening and closing.
Take into consideration the wear resistance of M4, but maybe the Millie will be similar??
Mine is pretty smooth and didn't require any break in. It's much stiffer compared to the Para 2 with the pivot bushing but for a conventional pivot, not bad at all. The blade is perfectly centered and the lock up is tight. It's about as good as it can be.
Push the lock bar all the way towards to the clip and work the blade. If that's smooth, then it's the detent ball. If it's still rough, then there might be some grit between the blade and the bushings.
