- Apr 3, 2011
Looking at the layered design, I'm thinking you could unbolt the plate that the tool arm locking knobs screw into, and replace those 3/16 or 1/4 inch spacers with 3/8 or even 1/2 inch. You'd have to get longer bolts and make new tool arms as well, but a conversion to 2x72 would require that anyway. You're not gonna be hogging out battle axes on this thing, but it looks like a potentially nice setup for a mobile sharpening rig for things like farmer's markets and such.I think rigidity would be a problem expanding it to 2X72. The tool arms are only flat stock. Looks to be 1/4" thick. The work rest is only 1/8" thick. Still, at 38 pounds it likely has some degree of sturdiness. It isn't intended to be a TW-90 or Reeder level grinder, but as an entry level or small backup grinder it looks quite promising.
2X42 works the same as 2X72. It is the 2" part that matters most. 3/4 HP won't hog down a bowie from .200" stock, but will quite easily handle smaller knives and handles.
From what I can get by using the 1/8" table as a measurement gauge, the frame is around 3/16" and the tool arms are 1"X1/4"
It appears to be an open frame DC motor, but the holes could be just for cooling. It would be good to check that out.
One thing to note is a replacement motor is only $70 less that the whole unit. I think if you eventually needed a new DC motor, Amazon would be your friend.
Yeah. That's why I was thinking use angle iron and just trim to fit in the bolsters, but the unbolt and use longer hardware is a better idea if it is applicable. I was also thinking in the future use servomotorkit.com for a 1.5hp that bolts right in. Also I the servo motors would have alot more control options.The more I look at the photos I think it is a TEFC motor.
Looks like a modified stepper motor.The more I look at the photos I think it is a TEFC motor.
Of course, you gotta put in the work to get the results.As someone who has had a lot of tools and equipment:
Before you start modding something new to you, learn to use it as it comes. Then you will know what areas it can be improved on and where to leave well enough alone. Often the weaknesses are more your abilities than the tool's fault.
I saw suggestions of tearing it apart and rebuilding it to a larger size. This will usually end in failure or at least considerable extra expense.
This is a 3/4HP grinder. It looks great as an entry level grinder just as it comes. Don't expect it to do what a 2HP KMG/TW-90/Reeder/etc. will do as far as speed of removal. Take your time and learn to get the max out of it without stalling the motor or bending the arms.
I'll tell you a little tory:
When I was very young there was a country store nearby. There was an old man who sat outside carving chains from sticks of wood. He used an old small pocketknife. I was fascinated. I asked how he did it and he said, "Sharp knife and taking my time." I found an old knife in the barn and tried to start carving a chain. I got nowhere. I decided that if the knife was sharper I would carve better, so I used a whetstone to make it really sharp. It cut my fingers quite easily, but did nothing to make the stick of wood into a chain. Later in life I realized the trick was that the old man KNEW how to make the knife carve a chain. So, it wasn't the tool, but the skill of the user.
