I've made fixed bladed knives for years but now I want to try folders and I have a lot of questions. One is what type of drill bit to use to countersink the blade rivet hole and the spacer holes on a lock back. I am thinking about a bushing in the tang to prevent the blade from jamming when I peen in the ends of the rivet. Do you still use shims and what thickness? Since cutlery steel is expensive- use the same steel for the lever/rocker? Heat treat the rocker because of the lug area? On the pin for the rocker, if you try to peen it seems it could crack the scales? All help appreciated.
