Hello,
So a little background. Im a farrier and do bit of smithing for my own needs like making tools and whatever I need. Im working out of a gas fire. I modified an old NC whisper 2 burner forge by firebricking up the front and cutting a side entry port.
I decided to start making blades when I needed a custom gift for each of the members of my wedding party. I decided to make cooking knifes from chainsaw chain. I've never made any sort of Damascus, or blades for that matter before. But I do forge-weld regularly when making horseshoes. Actually welding up the first chain seemed a lot easier than getting a good forge weld on a barshoe.
This is the first knife I've ever made. This is what Ive got done so far as yesterday.
Questions;
Forging; How mny times does one need to fold the chain once flattened out and somewhat squared up? I find Im folding just because I have some spots where the weld is not great so I lap it over 3 inches or so. until I end up with like a 3"x 1/8 x 1 1/4 billet.
Heat Treating; I normalized 3 times, and then hardened. I used 5-30 motor oil. Thats all i had around. I wold like to use Veggy oil next time. So I preheated the oil, and went to dip my knife. I found it very hard to maintain an even heat on the blade. (nextime I plan on using a tube inside the forge to put the knife in to avoid direct flame contact and hot spots.) It took me about 4 tries because the first few times I kept warping the blade on the heat treat, I think it was too hot in some spots. Then I tempered in the oven at 330F for 2 hours. Files skated off knife before temping. After temping the blade flexes slightly when pressed, which is good I think. Does it sound like i did all this correctly? Is there a quicker way to temper? Can I use clay to harden just the cutting edge? If so do I still need to temper?
Finish; I shaped up the blade and got bevel going with my Multi-tool belt grinder (36x2) before heat treating. After heat treating and tempering I used a scotchbright belt to get the scale off. Then a polish belt. But the polish belt left noticable grooves even with the finest rouge I had. Should I use a cloth polish wheel on a 6 inch grinder? Should I have just used Very finesandpaper? Whats the best way to get a good polish? Some of the scratches showed prominently after etching.
Etching; I used ferric chloride from radio shack. The bottle said "Ready to use". The etch came out really dark, I think it was about 4 parts water 1 part FC. Etched for 15 min then rinsed with Ammonia and scrubbed a bit with the scrubby side of a sponge. Veryu dark and dull. Is there a better way to achieve a brighter finish?
Final Sharpening; Now its almost got an edge on it, but I did not want to use the belt grinder to get my sharp edge because I don't want to take the hardness out of the edge. Whats the best way to do the final sharpening? Im thining about order some Norton combo stones (250/1000 4000/8000). Can I just use wet/dry sandpaper for now? Which grits?
Thanks!
Josh
Questions;
Thanks!
Josh
