New to knive collecting which knife should I get next?
You need to ask yourself if you want to explore different styles of knife, different steels, or different manufacturers. The possibilities are endless. You have been given some great suggestions. I would suggest you check out a traditional knife. There are thousands of possibilities there. You can get a nice Case stockman for about $35.
Emerson CQC7BW
All knife collectors need a Swiss Army Knife, I am looking at getting a Wenger Standard Issue, which is a lot like the Victorinox Cadet. The Cadet is with me all the time now that I see how handy it is. As for another knife, I'd get yourself a nice traditional, which you can pull out anywhere and not scare even the jumpiest sheeple. Same goes for the SAK.
Cheers,
Connor
Looks like you've already got a couple of assisted-openers, back lock, frame lock, Arc lock, flipper opening, thumb stud, and thumb hole.
A couple other locks to try out are the liner lock, Axis lock, and compression lock. Check out the Kershaw Skline, which is a manual flipper w/ G10 handles and liner lock. The Benchmade Griptilian (or Mini-Griptilian) is a good knife featuring the Axis lock. The Spyderco Paramilitary 2 uses the compression lock and also has G10 handles. The Spyderco Manix 2 uses a ball bearing lock, which is similar to Benchmade's Axis lock. The Opinels use a ring lock, which is pretty different.
If you're interested in different steels, the Griptilian and Para2 use 154CM and S30V respectively. The Opinels have an option of coming in carbon steel, if you want to try out a non-stainless steel. You can also look at the Spyderco Delica, which comes in VG-10 or ZDP-189. The Kershaw composite blade Junkyard Dog or Rake have a CPM-D2 cutting edge.
Some traditional folders might also be good. You can't really go wrong with a Swiss Army Knife. The Victorinox Super Tinker or Compact are both offer a good amount of function without being bulky. The Sodbuster design is also a great work knife, and the ones by Case and Queen are good examples of those. The Case Peanut is a popular smaller knife.
