+1. I'm pretty sure most of us have been at the "I'm hopeless and Can't sharpen" point before. It will pass.Downhill Trucker, I strongly suggest before you waste any money on a "sharpening system" read the post on Zero dollar sharpening by Magnaminous down on this page. If you learn to free hand sharpen, not that hard, you will be able to sharpen a knife anywhere, anytime, on a wide variety of materials. There is no rocket science to it, and it's way easier than you think. You can sharpen a knife to shaving sharp on the unglazed bottom of a coffee mug, a piece of brick, stropped on cardboard, and more. Sharpening systems are a trap and a crutch you get used to, and they don't fit in a pocket like a small diamond hone from Eze-Lap.
Sharpening systems are a way to make knife sharpening seem more compacted than it really is, so you will spend money on their miracle whiz bang gizmos.
Carl.
Carl, I live almost next door in Gaithersburg. My camera isn't the best, but it's probably good enough for youtube. I'd be happy to help with this project.
Allen
While I whole heartily endorse someone wanting to learn how to sharpen a knife, you should also learn how to keep a knife sharp with a steel or a hone. Simply put, it is a matter of re " trueing " an edge instead of removing material. Good luck!
Would be worth the trip alone just to hear some of Carl's stories first hand! You guys are in for a treat. Not exactly in my back yard, but if it was.... Looking forward to seeing the finished product.
Blessings,
Omar
Yes it is. Where the knife is sharper when properly done, you have not removed any material. If you will touch up an edge with a steel or a hone periodically it will last much longer between sharpening with a stone, diamond surface, belt or wheel. A chef steels his knife virtually everytime he uses it. I am sure there is something available that explains it better than I can. Good luck!
I met Carl last night and Omar is right! Carl is one of the most interesting guys I've ever met. In just a few minutes he showed me how to get a shaving edge using the bottom of a coffee cup and a leather strop. I love my Edge Pro and the incredible shiny edges it gives me, but to get a knife to do it's job (that would be cutting stuff), it's really not necessary.
THANKS CARL!!!
When I got home there was a new knife waiting for me that I had ordered last week. After a very few minutes to re-profile with a $4.00 stone, clean it up with a coffee cup and a strop, the edge was good enough to shave and slice phone book paper.
I don't think that I'll give up the EP, but I don't have to carry it with me when I'm away from home.
Allen
While I didn't have access to any of the nicer meatpacker's steels, I did a bit of work trying to find out more on this topic back here:
http://www.bladeforums.com/forums/s...-steeling?highlight=quick+close+look+steeling
Lots of speculation mixed in with a bunch of micrographs. I never did get around to testing with a borosilicate rod, but went as far as pricing some on the net - considerably less expensive than a higher end steel and likely better results, especially on the more wear resistant steels.
HH
Contrary to popular opinion, you don't need a meatpackers steel, or any other special purpose steel. Any kind of round or semi round steel surface will do. You are merely re-alining the knife edge, not removing any metal. I've used the shaft of a screw driver, handle of an adjustable wrench, and even the back of another knife blade. Of the screw drivers, I've had the best luck with Sear's Craftsman and Snap-on.
You can buy a real butchers steel, but it's not really needed.
Carl.
Does knife maintenance have to occur using a hard polished rod? Can it also be by stropping? I don't need a video to help me understand it. DM
No vid for us to watch?![]()
