T
tommytman
If I were you I'd get this sharpener or a Hapstone before the Wicked Edge,the problem with the Wicked Edge is the clamps don't seem to work that great and the stone selection isn't as good for them either and the other problem is you have to buy 2 stones for the sharpener.
The K03 is a great system and the only thing I recommend getting is the double fillet clamps and reinforced spring's,the reinforced springs are dirt cheap,if you are going to sharpen pocket knifes at 15 degree's or less then the double fillet clamps are the way to go.
I would get the Venev stones to practice with a lot of guys use them to free hand sharpen the you can use them on the K03 or a Hapstone or some other kind of system that use's edge pro format stones,you'd be fine starting off with a Venev 80 grit stone.
There are 2 reason's why I'm saying to go with the Venev stones,the first is because for S30V S35VN and S110V diamonds are your best friends for those steel's more so with S30V and S110V,I also find your better to keep S110V around 600 to 1200 JIS grit polishing that steel does not work at all and it will never be scary sharp and will dull fast with a polished edge.
The second reason to get the Venev stones is because there's no point buying bench stones and then having to start all over again with stones for a guided system.
That sharpener by the way is an older model and is just fine and when it's sold out your going to pay more for the newer model.
Also the clamp selection for the TSProf stuff is second to none and that's the main reason I got mine is because other clamped systems tend to handicap you more then anything a time's with their clamp selection.
If you email me at
wadenorton2008@yahoo.ca I have a grit conversion chart and you may want that because the Venev stones are rated in FEPA and the chart I have convert's them over to JIS.
https://www.statesllc.com/products/...rstar-kit-stock-free-shipping-conusbelow-cost
