Dave
If you've ever seen a blade sharpened/polished on a 2X72 Burr King with linen belts and CBN down to .1 micron, I think you'll change your mind about manual sharpening giving a better edge. I've seen an S90V blade that would tree-top hair, and shined like liquid mercury right off of the Burr King.
The linen belts and CBN are the difference.
doesn't look like $1600 to me. But what do I know...
sure you wont get a belt grinder in the middle of a food processing zone, but i have belt grinder in the wine storage area, without any issue, no dust on the bottles or anything crazy. if this isnt possible , i'll get a tormek over this any day. not only it's cheaper it's also faster.
keep in mind that maybe 99% of the pros just dont care. I tried to teach my cooks what sharp is without much results ... i sharpen all their knives when i cant stand how dull they are, do you think i'd tolerate any speed loss when i have to sharpen 10 dull knives just to see them scraping cutting boards with the edge 5 mins later ?...
and for working some time in my father's butcher shop the same applies... and it´s even more critical on industrial meat processing facilities where they have machines that cost a bit more but that cut a primary and a steep secondary bevel in about 20sec just by dragging the knife in a couple slots .... and those edges arent pretty but they work, the machine eats knives but throwing knives away cost less that having every guy stuck on a wicked edge for 5min 10 times a shift...
most of you (and i guess the designer of the device) see the market with the eyes of a knife and sharpening nut. thats usually not how things are working in a busyness.
I agree 100%. The basis is the wonderful wire edge that is created on the moving belts. Even @ 600 grit and the wire edge popped off; I finish with a cork belt at 1000 grit and then use the tried and true box strop technique. I use a Bubble Jig to control the desired sharpening angle. It produces a true flat ground edge. "Scary" sharp.
Fred
Now i'm lusting after a burr king 2x72 for the sheer possibilities it might provide. Started looking around at my $400 EP setup, spendy folders and other things that i don't use often and totaling things up...
The best machines are the variable speed ones, correct?
Got me thinking
