Just for clarity, your knife is hard to unlock when it is open and the lock is engaged, correct?
Lock stick is when the interface between the lock face and blade tang stick causing the knife to be hard to unlock.
This is opposed to just having a strong detent, which makes the knife harder to flip open.
The ZT has a replaceable steel lock face, and this is the first time I can remember anyone having any stick issues with any of the knives with the steel lockbar insert.
best
mqqn
yes its hard to unlock, it looks like theres som gunk on the blade tang im going to take it apart when i get home and clean it. cant take all the oil off though because i dont have any at the moment unless there's something i can get at home depot that would work pretty well?
you don't need to lube/oil the knife. so you can rub it dry. lubrication just helps protect metal to metal connection so it reduces wear and provides less friction.
you can add some later if you like.
you can get mineral oil usp almost anywhere if you want some right away. tho I would recommend doing a search for lube and picking a longer lasting lube so when you need to replace the lube in the future you will have a good idea what to get.
On the few occasions I've had a sticky lock, a couple of applications of pencil graphite on the blade tang, combined with a couple of days of opening and closing, has done the trick.
If you are near a Wallmart. Get a sharpie marker for where the blade hits the frame lock and Remington Rem gun oil for the blade washers. This is a cheap quick fix! For more time, effort and dough, I would get Nano oil 10 weight and send it to someone to carbidize the lock face.
Did you buy this brand new or used?
should the blade tang or lock bar already be carbidized? i thought that was the whole point of the replaceable lock bar. also, the ZT0562cf is bearings, not washers
