- Dec 7, 2008
So as things move forward making Balisongs trying to limit my mistakes:
Sequence Right or Wrong for a sandwich style, tang pins (Not Zen) PB Washer Bali? Possibly a caged Bearing
Measure Measure Measure everything
Profile blade
If not using pg steel Surface for Parallel
Sand and Buff pivots to final dimensions
Drill Pivot tang pin hole/s slightly undersized
Ream for Pivots
Counter bore for bearing cages
HT
Clean up face
Clean pivot holes Final ream
Grind
Finish grind
Install tang pins
Drill/Fit handles Latch
Dry fit
Adjust back-spacer, washers, tang pin divots on handles for latch...
Assemble
Embellish
What is missing or out of sequence? Tips tricks!
Profile blade
Ream for Pivots
HT
Clean up face
Grind
Finish grind
Install tang pins
Dry fit
Assemble
Embellish
