Well, price can vary rather widely depending on just what exactly you're looking for. A 2x72 grinder is the most recommended size for knife making, and is plenty suitable for most garage/shop tasks as well. Expanding from that, how much do you want to be able to do? You can get a "S.L.I.N.G" kit from Polar Bear forge that will be good for flat grinding or contact wheel grinding, or I think he makes one for both. Some assembly is required, as well as sourcing wheels, hardware, and a motor, but you could likely build one for less than $500 if I'm not mistaken.
A little more "turn key" (but not quite) is a chassis from Oregon Blade Maker. All in, you can have a pretty nice setup for under $1000, including a budget vfd (variable speed) and motor.
If you get into the $1500-$2500, you start looking at several more options: Northridge, KMG, Pheer, AMK, Wilmont LB1000 etc... with variable speed set ups.
The next tier would be up to around the $4k range which gets you into TW-90 territory, Wilmont TAG, Hardcore, and maybe one or two others.
At the end of the day, they can all remove material and make knives. Some will have more features or be easier to use or do more with, but whether it's worth an extra $500, $1000, $1500, $2000 etc.... is your call.
Wilmont Grinders is probably about 2 hours or so from Charlotte. You might see about taking a drive there and talking with Chris Williams, see a range of grinders, and talk shop.
