Hello forum!!
I am a newbie as stated and have been lurking around reading a bunch of posts learning. I have decided to build a forge to give me an opportunity to tinker with. I am using an old hot water heater tank that I cut to 15" long and 16" diameter. I also split it length wise and the plan is to decrease the diameter to 10". That will give me a roughly 6x13 in chamber using 2" inswool. I also want to place a fire brick in the bottom instead of just laying material on the wool. I will be coating the wool in satanite and probably ITC-100 as well. Is the chamber to small for a single burner? Can it be bigger? do I need an opening in the back at this point? How should the nozzle (propane) be positioned? Does it point to the center of the forge or should it come in on the edge of the chamber to swirl the heat? how far into the body does it protrude? I am just wanting to pound on some steel at this point no forge welding at this time.
I know this is a lot of questions and being the type of person that I am I want it to be functional while I learn the basics and maybe be expandable as my skills increase.
Any help, pointers, suggestions and comments welcome.
Thanks in advance.
Eric
Thanks in advance.
Eric
