I hope I'm in the right part of the forum to post my newbie questions... (at least, this thread might go into sticky thread as warning- look what happens when daft person thinks he can make a knife) I lack the skills of a bladesmith, but am an engineer entertaining the thought of producing knives on very small scale. I can go into details (and much more questions, inevitably) later if I don't get kicked out, along with this thread, from this subforum.
I've been trying to design a blade for a (friction lock) folder knife- it wouldn't be a traditional folder, but am not particularly fond of modern ('klingon', as I call them) designs. So, I was hoping to design a very sharp cutting instrument, preferably elegant, but 'modern-ish' (no link to hunting designs, various peasant or fighting knives, like Bowies and Navajas), but am at my own assesment failing miserably at doing so. The blade seems too thick, even if I've used probably too thin section (1.75mm, or 0.07") for the blade length (in this pic, edge to tip length is 85mm, or 3.35", blade width is 15mm or 0.6"), the overall 'blank' length in the pic is 105mm (4.13")... Lines seem to be all wrong at the tip even if I used distal taper (from 1.75mm to 1mm, starting at the middle line, at the ricasso), but am clueless how to correct it without a) changing first saber grind angle at the tip (which doesn't seem prudent), or b) adding a swedge of a sort, which I'm not particularly keen on doing (one reason is that it might add to 'aggressive look', which I'd avoid, or want to add to another version of the design). How could I improve the shape o the tip (I would be satisfied to get very good cutting performance from the recurve 'belly' to within half an inch from the tip), but would like ti improve on seemingly not so good performance at being stuck into stuff).
Another thing is the edge shape- I was hoping to use a local variant of D2 steel (which I'm told can be obtained quite cheaply), and I've used 36° included angle for cutting edge. Being clueless about particularities of various steels, I was wondering if that's an appropriate value for the material chosen. Thanks in advance, and I hope my questions/design doesn't seem to be too amateurish (and certainly, that I'm not coming off as a wannabee-ish type)...
