- Oct 13, 2011
first time firing up the ole evenheat since getting it wired up. I tried five 12c27 blades, and 2 came out well but 3 came out soft enough to cut with a file relatively easy. all were plate quenched at the same time with the only difference being the time it takes to pull blades out and lay them on the aluminum blocks and the time it took to cut them out of the foil and chuck em into the dry ice slurry. three questions I guess, why did some turn out and others not? was it likely the ones I did first that cooled wrong that ended up soft? can I simply normalize them and start fresh or is the steel ruined somehow? and should I have taken two or three at a time rather than all 5 at once to keep the times more strict?
formula I used (from sandvik):
1. soak @ 1975 (I went for 15 minutes)
2. plate quench as fast as possible and let cool for 5 minutes.
3. place in dry ice/acetone slurry
4. temper at 300F for 30 mins, twice
since I totally blew my 440c blade as well, I can assume this won't be my last questions so thanks in advance
Royce
Royce
